Oh sorry, I thought I did! My bad! I looked through the forums and found that it might be that the model isn't water tight? I still don't quite get why it's just the top/bottom that's having issues....
kmanstudios 1,120
This looks like classic 'non-manifold' or 'non-watertight' issues. It looks as though Cura is trying to close up edges it thinks are proper connections.
I agree that the .3mf file is needed, but also the model as it is as well be to be definitive about the issue. This would be the .stl or .obj type and not a cura file.
Also, did you download or did you make it? What program?
6 minutes ago, kmanstudios said:This looks like classic 'non-manifold' or 'non-watertight' issues. It looks as though Cura is trying to close up edges it thinks are proper connections.
Aye, it would seem that way... I included the .3mf in my previous post, and I'm including the .STL here.
I made the model in blender. I've tried merging my objects together into a single object thinking that might solve it, but no luck. How do I go about making it watertight?
Wow - that stl file has a LOT of triangles for just a barrel. I'm not sure if you need that many triangles for all that wood grain and if they will all be visible. I would probably reduce the number of triangles just so that I could work with the object faster in CAD. But that won't help your issue.
So I looked at your STL file in xray mode in cura and there is lots of red - particularly at each of the metal bands. You have surfaces just hanging in air that don't connect to anything solid. That might be the only problem - not sure.
What CAD are you using? Most cad programs won't let you do this. Most CAD programs deal only with solids but some cad programs like sketchup let you deal with surfaces which is unfortunate as surfaces are unprintable unless they are connected together to make solids.
I think you are going to have to "go inside" your model and remove the extra surfaces.
Also some CAD programs that let you deal with surfaces let you paint the surface as "inside" or "outside" the solid. For example a cube would have 6 faces and you have to tell sketchup to make the outer surfaces the "outside". Sketchup isn't smart enough to do it all alone. This "outside" versus "inside" property ends up in the STL and if the top rim of your barrel has it backwards it can confuse cura.
What CAD do you use?
You can also repair this model using netfabb's free service on the web. That's a quick solution. It's free but you have to create an acocunt.
burtoogle 508
Hello @cHubbz, please save the project file (File -> Save) and attach the resulting .3mf file to this thread so it can be investigated. Thanks.
