Hi Jimmy D
I'm an in-house architectural model maker and I use various programmes to achieve the end result in MY work line. I have used MicroStation for years and I am most comfortable with that but here at work drawings are produced in AutoCAD ( could never get on with it!) so I use both programmes to resolve issues switching and saving between the two then using Rhino to refine and save as .stl for printing.
The architects are starting to use Revit here too and we did try to export directly as a .stl but we had issues with what was required for printing and what Revit produced, so I had to redraw it in Rhino. Admittedly we've only tried this once and I'm sure there is a resolve but because of time we can't expect every architect to be trained in the ways of drawing for 3D printing so for the moment it's easier and quicker for them to send their stuff as .dwg to me and I work the magic with AutoCAD, MicroStation, Rhino and Cura to produce the parts I need for my models.
As Daid says it's what works for you and what achieves the best results for you.
Regards
Daid 303
The best tool depends on the job and what you are used to. But SketchUp isn't the best tool for 3D printing, it's one of the worse actually, as it has a tendency to add internal faces and holes around the model.
I'm playing around a bit in SpaceClaim, which I really like. And most likely cheaper then AutoCAD
(still expensive tough)
