bridging not making best use of exisiting walls
td1
Posted · bridging not making best use of exisiting walls
Cura 4.2.1
It strikes me that the optimal path for bridges ought to be horizontal because a) shorter distance, and b) start and end on existing walls with solid foundations.
Please see layer 41 towards the end when bridging starts, we have long diagonals ending on a very weak line at the top of Y, and naturally the whole layer droops at the top of Y.
Would be handy if someone could recommend improved settings, else is this worthy of a software bug/feature report ?
Thank you in advance
Tim
X_carriage_-_modified_MK3_fan_blower.stl modified_MK3_fan_blower.3mf
    Thanks for the project file. The remedy is easy, just enable the bridge settings in the experimental section and the first bridge layer becomes like this...
    You will find there's a bunch of settings in there for tweaking the bridging behaviour.
    Wowzers! That's a scary long and bunch of detailed settings right there! Thank you @burtoogle I guess because it's in Experimental the issue I reported has already been recongnised and will trickle down to default behaviour in a future release ?
        • 27 replies
