Thanks a lot, that does the trick. Really appreciate it. Will this affect the quality of the print in any way? using 0 (instead of 3, the value put by CURA before).
Also, I've been in the situation when the roll of filament finished before a print finished. All good, the sensor got it, I put a new roll in, and the print continued. However, I got a small gap in the print, an imperfection. Is there something I can do about this, if this happens again?
I've uploaded a picture, and you can see on the top of the print, 1 CM from the top going down, a line going all the way along the print. That's what I'm referring too.
Thanks!
ahoeben 1,981
This is controlled by the setting “Support Horizontal Expansion. Feel free to set it to 0.
The reason it is not set to 0 by default is that printing very tall shallow towers of PVA on a PLA print does not work very well.
