The Custom Jobname Prefix plugin is now named Custom Printjob Naming plugin.
The plugin now has separate fields for a prefix and a postfix. It also lets you specify a path to use. This path will be limited to a subset of all outputs; currently removable drives, the Duet RepRapFirmware Integration and OctoPrint Connection plugins are supported. If the path option is supported by the plugin, a small folder icon will appear next to the job name as a quick shortcut to set the path.
1
ahoeben 1,582
I'm working on a version of the Custom Job Prefix plugin that also supports a configurable postfix (I'm going to have to change the name of the plugin...). If you would like to test it out, download this development snapshot and drop it onto the Cura buildplate as if you were opening a 3d model.
SpaceDiceMan 1
I so needed postfixes! Work great when both prefix and postfix are filled in settings. However when you leave the Prefix empty, everything in postfix settings is ignored and the printername is added to prefix. In order to get just postfix I have to add dummy character in prefix. Is there way to leave prefix empty?
ahoeben 1,582
@SpaceDiceMan: good find. I have already fixed that problem, but have not yet made a new development snapshot. I will probably do so tomorrow.
