Oh - instead of 100% infill, try setting shell thickness to a high value - for example 200mm. This might give you a better pattern of infill.
Or instead consider modeling this in CAD with a top and slicing with shell thickness an integral number of .4mm diameter passes e.g. 2mm and unchecking "solid infill top". Or is that what you did?
gr5 1,876
I don't know much about this subject. But I do know that Joris, who is the expert on making cups that don't leak, uses a thicker nozzle. The Ultimaker has a .4mm nozzle diameter hole. He uses larger - I think .8mm or 1mm maybe. I found it is easy to change the nozzle (make sure you heat to 180C first and be careful not to destroy the brass - be gentle) and they are very inexpensive online.
Hopefully someone else has more information than me. Or try google.
