Posted · Dual Extruder and Cura 4.3.0
Hello everyone,
I have a dual extruder printer.
I want to print with the second extruder only . I use Cura 4.3.0 (see picture attached) but the first extruder works only (see gcode file attached). So, i have to correct the file.
Did I make something wrong or incorrect settings ?
Please, let me know.
Best regards.
Bernard
CFFFP_Cone_support_bobine_avant.gcode CFFFP_Cone_support_bobine_avant.3mf
    at the left red arrow; buttons to select the extruder to use for the selected model
    at the right red arrow; where you can turn of/on a extruder
    In the detail setting you can also select a specific extruder  for things like support, brim, infill etc...
    Hello everyone,
    I don't have the option showed by the right red arrow. I choosed the extruder with a right clic (context menu) on the part.
    This morning I have made an other test :  i have disabled the first extruder in the menu : settings/extruder 1/ disable extruder. And it works.
    For information, when i install a new version of Cura , i always keep the previous one, just in case.
    I have tried to reinstate the new version and  delete the old one, I still don't have the option in the print settings menu on the right, and still the same problème.
    Regards.
    Bernard
