Posted (edited) · In dual extrusion, second material sliced every other layer
I am attempting a dual extrusion job. In the design, I have some solid cylinders (material 2) oriented horizontally and spanning several layers within a larger cylinder (material 1) which is vertical.
When I slice this, the horizontal cylinders are sliced only every other layer so the printer extrudes "material 2" every other layer while "material 1" is extruded every layer.
Any idea of the reason this is happening and how to resolve this issue?
Thank you!
Edited by murandi
    Posted · In dual extrusion, second material sliced every other layer
    That sounds strange.  It sounds like a problem with your model.  Maybe the seam where the two cylinders connect has gaps or other errors in the model.  Please:
    1) Show some photos to explain both in normal view, xray view, and slice view
    (for xray view there is a drop down in top left area when in preview mode)
    2) Tell us what CAD you are using or is this a model from someone else?
    The thing is that the problem occurs "within" the horizontal cylinders. When I enlarge the cylinders using the CAD software and I slice it I see more alternating layers, i.e. one layer with both materials and one with only "material 1".
    1) Attached are some screenshots
    2) The CAD is Autodesk's Fusion 360
    Edited by murandi
    clarity
    okay.  Strange.  Let's clarify:
    1) Do you export 2 STL files from autocad?
    2) Are the two files exclusive?  I mean in the image just above the blue cylinders pass through "holes" in the yellow part, right?  At no point are both materials occupying the same space?  if not then you need to do a boolean operation where you subtract the blue part from the yellow.
    3) I suggest you play with all the "mesh fixes".  Please make all mesh fixes options visible and then look at each one and toggle the value if it even remotely might have something to do with this.  Looking them over, any one of them could be related but the most standout one: "alternate mesh removal" is very likely involved - you probably want to uncheck that.  Read what that does - it sounds a LOT like what is going on here but it should not be a problem if there were no bugs.
    I had almost the exact same issue and found this thread while searching for a solution.
    In the end, for me it turned out to be a problem with my 3D model. The main body (the one you show in yellow) was intersected by the smaller bodies but there were no actual holes cut from it. My two bodies were just occupying the same space. I am using Fusion 360 and solved the problem using the Combine tool, selecting Cut and Keep Tools to punch holes through my main piece using the smaller bodies as the tool.
    After that, re-exported the .stl files, opened them in Cura, merged them and my smaller bodies no longer only print every second layer. It makes sense if you think about it, the program sees two bodies occupying the same space and is printing 50% of one and 50% of the other.
    Hope that helps!
    Edited by surfacefeatures
    clarification
    • 4 years later...
    Hope that helps!
    Four years later, this post saved my print 🙂
