tinkergnome 929
The answer depends on how exact do you want to know it.... 😏
The simple way is: compare the header (first few lines of the file) of the "good" file with the non-working ones.... and you will probably see what is missing. At least the material-id is mandatory AFAIK.
If you want to explore more details: save the log files of the printer to the USB stick. You'll find the exact error messages in there.
Quote
;START_OF_HEADER
;HEADER_VERSION:0.1
;FLAVOR:Griffin
;GENERATOR.NAME:Cura_SteamEngine
;GENERATOR.VERSION:2.6.2
;GENERATOR.BUILD_DATE:2017-07-06
;TARGET_MACHINE.NAME:Ultimaker 3
;EXTRUDER_TRAIN.0.INITIAL_TEMPERATURE:220
;EXTRUDER_TRAIN.0.MATERIAL.VOLUME_USED:13228
;EXTRUDER_TRAIN.0.MATERIAL.GUID:938757ed-22ac-4311-ba0e-678005a7042d;EXTRUDER_TRAIN.0.NOZZLE.NAME:AA 0.4
;EXTRUDER_TRAIN.0.NOZZLE.DIAMETER:0.4
;BUILD_PLATE.INITIAL_TEMPERATURE:60
;PRINT.TIME:17552
;PRINT.SIZE.MIN.X:9
;PRINT.SIZE.MIN.Y:6
;PRINT.SIZE.MIN.Z:0.27
;PRINT.SIZE.MAX.X:174.577
;PRINT.SIZE.MAX.Y:134.979
;PRINT.SIZE.MAX.Z:13.97
;END_OF_HEADER
rhoogenboom 3
I cannot find the edit button of the post, so here are the files,.... There is one which will print from USB, the others just don't, neither can you send them to the cura connect queue via Cura.
If anyone can shed some light on this, much appreciated as it is darn annoying not able to print with an UM3 and a USB stick with generated models,...
Cheers,
Richard
Velg - original - v3.gcode Bottom Pad-v3-1x-0.4-L.gcode flat hoekstuk - v4.gcode Raincap-v2.gcode
