Ultimaker 2+ filament stuck in Bowden Tube after running out of filament mid print
Posted
· Ultimaker 2+ filament stuck in Bowden Tube after running out of filament mid print
Hello Harry,
is the filament stuck in the bowden or just in the hotend? I would remove the bowden on the printhead side and pull it back a little to be able to grab the filament where it goes into the printhead. Then use the menu option Maintenance -> Advanced -> Heatup Nozzle and heat up the nozzle to ~90°C for PLA and then pull it out firmly as you would do if you use the "Atomic Method" to clean the nozzle.
Posted
If it is stuck in the Bowden tube and you are not able to get it out as Reiner described, you can also try to completely remove the Bowden with the filament and hold it under warm water. PLA gets soft at 60°C so your chances are higher that you will get it out.
Posted
Thank-you very much to Both of you for your suggestions, I tried Reiner's first and it worked a dream. I really appreciate you taking the time to help me!
reibuehl 40
Hello Harry,
Best regards,
Reiner
Smithy 1,131
HarryB226 0
Best regards,
Harry
