25 minutes ago, ahoeben said:You can try lowering the Support Horizontal Expansion setting.
Thanks for the tip, lowering the horizontal expansion to 0mm actually removes all the vertical unnecessary supports, so I guess we won't need to customize our own support in this case.
Although I have to ask: is this recommended? I understand that a higher horizontal expansion makes the support sturdier, but is it necessary on parts that already support themselves?
ahoeben 2,047
The STL format does not support multiple separate bodies in a single file. Other formats such as 3mf do. If your CAD software exports 3MF files, that might be an option to load your custom supports and print them as support using the "Per Model Settings" tool.
