Thank you Johnse for your feedback. Yes you are totally right, such a slicing strategy would reduce the surface quality however it would probably lead to even denser parts which is the property I am more interested in within the scope of this project. In fact, I am trying to get the highest density possible with the least inter-line and inter-layer air gaps which promotes a higher optical transmission...
Regards,
Reda
johnse 30
The typical slicing strategy is to alternate directions so the layers cross at 90 degree angles on alternating layers. Only the wall lines print atop each other, and trying to offset those would cause a rough outer surface.
