The upper surface of the translucent plastic part has two recesses, where the print head housing "grips" it.
So when pressing the "release"-lever, just apply a LITTLE bit of pressure down on the translucent part and you should be able to pull the core out easily.
Job_van_gennip 23
Long shot, but i have done this wrong some times as well. Have you unloaded the material before pulling it out?
Smithy 1,110
It could be sometimes hard to pull out the print core, but when I wiggle it a little bit the core comes out.
