Posted · support interface roof extruder (first layer!)
I am using CPE+ and PVA. Generally I have been printing my supports from CPE+ entirely, but in order to get better results on complex support surfaces, I am trying to use PVA as the interface layers. This is causing issues because it does not bridge well at all on top of the gaps of the support below where the interface starts. For this reason I was hoping I could print the first layer of the roof with CPE+ then the other support roof layers with the PVA. Thoughts?
Thanks!
