Thx for your response!
Problem is that I have no materials in my CURA 4.4 material settings. Only 1 material called "unknown" that I cannot edit.
Tried to import several files from the material folder (for example: "generic_pla.xml.fdm_material"), program says Import done, but no results.
Can someone export his material settings and give me that file to try?
This problem also makes that I cannot select material when I want to create a print file...
Thanks in advance!
Oliveros 11
You need to know the setting for PLA and ABS?
Smithy 1,146
Then generic material profiles are included in Cura. Or do you look for something else?
