both (protoface & cura in the jog tab) of the work on the same side that is the weirdess.
and when clicking home on the x-axis, the tray moves in the right direction on to the stop switch.
I have to be honess, I like cura more than protoface (dont get me wrong, the apps its self is great but I like a all in on apps better, slicing and printing) So I havent done alot of print in proto.. i guess, i'll have to try it and see if I get the same problem.
illuminarti 18
Does this also happen with other slicers? My guess would be that your firmware is configured wrongly, so that the motor is driven backwards. If you use the printer control interface in Cura, or a tool like pronterface, and step the head around, does it move in the opposite direction to the direction you click on?
