PLEASE HELP - Line Skipping Problem
Hisham
Posted · PLEASE HELP - Line Skipping Problem
Hi everyone. Each time the design of my file change from straight shape and spread into other angle, the printing line will skips and ruining my printing. If you see both picture shown that there is a line breaking from below/previous layer(this most of the time will make the print unstable and will breaks mid print!).  I checked the files in Preview mode in Cura 4.4. When I choose to see in Layer Thickness Color Scheme, it shown that at exactly the place where the problem occurred, the color scheme changed from yellow(thick layer) into blue(thinner layer), so I guess this happen because of the printer starting to print with different layer thickness so that is why it breaks. I have tried to disable 'Use Adaptive Layers' function in Experimental tab to try making the layer stay consistent in thickness throughout the entire print, but the problem still happening. So what I am missing here? Thanks in advance.
    Well even using your GCODE file which has all of your settings in it, i am unable to see the gaps your seeing. Could possibly be your printer setup settings in CURA. Confirm your settings. Possibly try version 4.2.1 which is showing me the STL and GCode files without gaps or blue layers in between.
        • 21 replies
