Im using CURA 4.2.1 and after loading your STL and GCODE i do not see any blue layers or line breaks in preview mode.
So in your opinion, the problem is not my STL files but either my CURA settings or the problems is in my physical printer itself?
Well even using your GCODE file which has all of your settings in it, i am unable to see the gaps your seeing. Could possibly be your printer setup settings in CURA. Confirm your settings. Possibly try version 4.2.1 which is showing me the STL and GCode files without gaps or blue layers in between.
mikepasquale1 0
Upload the model STL. I think you have an issue with an interior face thats causing it to print a support instead of seeing it as a wall.
