Posted · PVA Support section
Hi !
I use an Ultimaker S5 and I have recently started having problems with preparing a part that requires PVA support. As you can see in the picture below, the support structure isn't convering the entire section of the part, it leaves a gap between the structure.
image.thumb.png.1c059b439784db4b4bd6f3610dbe349b.pngimage.thumb.png.67aa428e926ba4bee30db380a8e02e14.png
I have been browsing around for other options in cura's support configuration but I can't seem to find anything that will fix this. I generally use Cura's default profiles for materials. Currently using Ultimaker CPE+ and Ultimaker PVA.
- I am using Cura 4.4.0 BETA at the moment and I have a feeling this only started happening since.
- So far, changing support placement from Everywhere to Touching build plate doesn't change anything.
- I tried changing from PVA to Breakaway and the support covers the entire section, so this only happens with PVA.
- Also tried with a diferente part and the same problem happens.
          • Heart
        • 4 replies
