Another issue could also be a disconnected cable on the sensor board inside the printhead, as described in this post:
Regards
Edited by Enigma_M4Another issue could also be a disconnected cable on the sensor board inside the printhead, as described in this post:
Regards
Edited by Enigma_M4You might also have tightend the screws on your buildplate too much.
Please first make sure your buildplate bottom to top distance is set to about (I think 14 mm, not at the office so I can't verify this right now), then manually level the buildplate while keeping the total distance close to this number.
Then you could try active leveling again.
ultiarjan 1,219
first thing that comes to mind is checking if the cable connector in the printhead is properly seated. Have a look at this;
