no text
Edited by Programify- 1
no text
Edited by ProgramifyUltimaker does not announce their firmware updates in advance. When a new version passes the testing procedures currently in place it is usually published something like a day later. If it does not pass the testing procedures we will never know of that version.
Ultimaker is looking into the topic of unnecessary priming in the Pro Bundle. Please keep in mind some priming is necessary to ensure that the printcore is emptied from old material and properly primed with the new material. The amount necessary is logically a bit larger than what you would extrude in a standard S5 in order to be on the safe side in terms of color and material mixing. But if the same material is loaded as was in that printcore during the previous print job one could skip the extensive priming and just make sure the printcore is primed at all. This is what is being looked into atm afaik.
no text
Edited by ProgramifyOn 1/20/2020 at 1:29 PM, Dim3nsioneer said:Please keep in mind some priming is necessary to ensure that the printcore is emptied from old material and properly primed with the new material.
Yes priming is necessary, and I personally don't mind the waste material. But just unloading into the chamber is a really bad idea. Every time it unloads one of these long strings there's a big chance it will get caught by the z-screw.
Edited by NBullI'm having the same issue with S5 and material station but I already have a newer firmware 5.5.12. Same phenomenon - several repeated extrusions of 25-30cm strings before and after every print. Can't really see any benefit of it just waste of material and time. I'm not aware of any feature to adjust or switch it off. For repetitive prints it would be nice to have an option not to unload & reload the filament from the material station.
Edited by elescs
I'm having the same issue with the S5 Pro Bundle.
I have about a gram of material waste every print cycle from the start and at the end. If a firmware update came out allowing the option to choose whether the print core should be primed or not that would be most welcome. I am in manufacturing and the time added in addition to material waste is something I wish could be avoided...
Dim3nsioneer 557
I can see a little bit of the material station in the second image. The repeated priming is default behavior with firmware 5.4.27 for S5 Pro Bundles. Revert to 5.2.11 is not a good idea in this case as that version does not have support for the Material Station.
Improvements of that procedure are currently worked on afaik.
