Even though low temperature printing works great now, I did notice another issue. If I am trying to print with PLA (settings: nozzle 200°C, bed 60°C) only the bed is heating up and if I move the cursor on the nozzle temperature it shows something like 26°C / 0°C. There still is the obvious workaround of setting the nozzle temperature manually but I would be very happy if there´ s a way to solve this properly. @tinkergnome could you help me out once more?
tinkergnome 929
In short:
If you still use the "Marlin" flavor, check the start script and the temperatures in Cura.
Or you can show the first part of the generated gcode here (as above).
For gcode-flavor "Ultimaker": double check the selected material on the printer.
As it turned out I simply wasn´ t patient enough. As soon as the buildplate is getting close to the desired temperature (about 2°C below) the nozzle starts heating up as well. This is also the point at which the endtemperature of the nozzle switches from 0°C to the desired 200°C. This is what caused the confusion on my behalf, as I did not expect the end temperature to change at any point. Thanks anyway for helping!
tinkergnome 929
Yes, but the minimum temperature can be changed:
properN00b 1
Thanks, this worked just fine!
