That's quite annoying. I guess Sketchup failed one more time.
Strange thing is I tried it with Slic3r just for fun and it appears to be able to generate the Gcode without any issues.
I wonder if in future versions of Cura there shouldn't be a pop-up warning the user that their file is broken and that it probably won't print correctly?
IRobertI 520
Your file is broken. Take a look at it in X-Ray view in Cura and you will see red areas that indicates a problem with the model. You can try running it through an online repair tool like the one from Netfabb and see how that works.
