11 hours ago, Enigma_M4 said:Hi,
as the printheads of the S5 and the UM3 are NEARLY the same, the following two youtube-videos by @fbrc8-erin might help you:
and
If the fan bracket has the right position, the -realy strong- magnets should have enough power to hold it securely and reliably in place.
Regards
It's not the problem unfortunately. the magnets work well still. As you can see i had printed a fan guard holder, but this popped off during a print. I'm looking into what may have caused this, and this is also why I wrote this post.
Job_van_gennip 23
Could you make a picture exactly from the front of the printer head. I am curious if your bracket still alines correctly? I would also contact your reseller.
Enigma_M4 120
and
Regards
andbaglin 0
Yeah is pretty screwed at the moment, since i removed the fillament to make the printer work again. I have contacted the reseller, but I was just wondering if this was common or happened to others.
