I don't see the enable combing checkbox in your settings, or is it gone when using a UM2?.
That should follow the the oustside lines back, instead of crossing the internal of the vase.
I'd like cura to retract at all blue lines when moving from one point to another, but I have not found a solution for that yet.
To avoid stringing I stiil have a 13.04 version, Might not work for a UM2, but the downpoint is 13.04 gives a large Z-seem.
(layershift on the same radial point).
Following this topic for other input
gr5 2,210
Very beautiful. First I would seriously consider a different slicer. Vases are special cases. Try kisslicer maybe.
If you want to stick with Cura, look at the part in slice view and try to find these strings. They will show up as blue lines (blue means non-extruding). Check to see if there is a vertical movement shown in slice view - you need the latest cura 13.11 to see this for a UM2 print as there is a bug in Cura 13.10 where it doesn't show the vertical blue line on retraction for UM2 in slice view (even though retraction is there).
If there is no vertical line it is likely (possible) that Cura is not retracting. But if it is then the usual ways to fix stringing are available to you. Basically you can reduce stringing by lowering the temperature to as low as you can go. I would do a stringing test first. But if I want to eliminate stringing typically I just go to 190C and print slower - like 20mm/sec. This may not be an option for you as your Vase might take days to print - not sure. You might want to buy a UPS (uninterruptible power supply) before you start a multi-day print. Here's how I did my tests on stringing (first photo):
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
