I've been printing with 3d Printers for a few years now and .06mm is a very low layer height. I print around there to show off a gorgeous model like the Yoda. It's kind of a waste of printer time to print that thin for a phone case.
The first layer at the height is very tricky. As illuminarti says set the first layer height to .2 or at least .15.
illuminarti 18
Did you set a different first layer height? Trying to print a first layer that is just 0.06mm is going to be very tricky to get right. You would do better to print the first layer at about 0.2mm or more, so that any slight variations in the level and flatness of the bed won't be so critical, and you won't be dragging the nozzle through glue.
