I did let the print finish and it was somewhat of a disaster. The travel between the tower and my part was rife with strings which created quite a mess.
I've abandoned the use of the PVA support material - which removed the "prime tower". I'm using the nylon itself now as its own support material. It prints much better, but removing that nylon is a chore.
IRobertI 513
That's a "prime tower", it makes sure the nozzle is full of material before starting on the actual print (it can also help wipe residue off the nozzle so that it isn't dragged into the print). Some materials are more "runny" than others and loose a bit of material from the nozzle which means you might get a little bit of underextrusion when swapping between the materials. For PLA they've managed to tweak the temps and timings so that the PLA is printed just barely hot enough to extrude properly but still be basically ooze free when swapping nozzles, that's why it can be printed without the tower.
