Or try slightly thinner, like .38mm.
Hi, thanks for the replies.
Of course, the line width is set to 0.4mm and also the nozzle size. Also if I try to set thinner/bigger lines, for example 0.38 or 0.42 instead 0.4, the nozzle will move 2 times over the Walls, which are 0.4mm. The same result is, when I make the walls thinner than 0.4mm.
It can also not be a solution to work with wrong nozzle or wall settings, then I will get other trouble.
The problem is to remove the support when the lines are 0.8mm.
Greetz CR
Edited by CumpyRules
Framar 25
What's your line width setting in Cura? Be sure it is at 0,4mm.
