Did you have any success with respooling it or did you get it to print reliably in any other way?
We are experiencing the very same problems with this PAHT CF15.
Regarding comparisons to other filaments, I understand PA-based filaments are very hydroscopic (far more so than PLA), but everybody and their uncle kept saying that about PVA as well, and drying it again and again and keeping it in the Material Station only increased its brittleness for us. In the end the successful solution was to keep our PVA in the open for several days, and by absorbing just a bit of moisture from the air, it became smooth as silk and printable again. I'll just leave that as a side note here.
Now to get back to this stuff here, BASF's TDS for PAHT CF15 states:
Quote
Drying recommendations to ensure printability: 70 °C (158 F) in a hot air dryer for 4 to 16 hours
Optimum drying recommendations for best mechanical part properties: 80 °C (176 F) in a vacuum oven for at least 40 hours
Looking at it that way, it should not be possible to over-dry this in any way, it's the dryer the better full stop.
Your 200 F (93°C) may have been a bit too hot, for how long did you condition it this way?
Unfortunately, I have not yet had the possibility to try these recommendations, but I'm very interested in your experiences.
geert_2 545
In PLA-based filament it is known that microcracks can grow if the filament is bent or stretched (thus kept under a load) for a longer period of time. So, don't let material sit still in the feeding-traject after the print is finished, but unload the spool immediately.
Some materials also get brittle due to changes in crystal structure, becoming more crystaline (often reversible), and due to moisture absorption and damage (not reversible as far as I know). Both happen in PLA.
Keeping it dry obviously helps against hydrolysis. But I am not sure what the best solution is for "un-crystalisation"? Melting should help, but then you lose your filament. Heating up to the point just before deformation might change its molecule structure in both ways: making it soft again, or rather making it harder (encouraging crystal growth), similar to post-curing and annealing. I don't know which one wins. And your warm room might speed-up these effects?
I don't know your material, so I have no idea if it is affected by these phenomena.
Try what the effect is of heat on a few short pieces of this filament.
Keep in mind that when heating it too much above its glass transition temperature, it will shrink in length, but get thicker (e.g. from 2.85mm to 3.10mm), and then it may no longer fit in the bowden tube or nozzle. You could also try unwinding it manually, and manually straightening it a bit, after which you release it again (to stop crack growth), so the bending radius is not as tight as before. Then it will get stressed less in the feeder. It may take trial and error.
It could also be a bad batch or spool, or a filament that is very brittle by nature, especially if it is a filled filament.
Pictures:
Microcracks in PLA/PHA filament after straightening it, and then releasing it again, so the stress is off. If the bending stress would be kept on, these cracks would keep growing until the filament would break.
Projects 2
Any other thoughts? For now I am going to try and re spool the material into a much larger spool so that the radius is larger. this stuff is so so stiff and brittle. I tried heating it up to 200f and it was able to bend to about 5 degrees before snapping. Its almost like it needs an inline heater to bring it up to 250f before it goes into the feeders (both the feeder behind the machine on an S5, and the hot end.)
