cura 15.04.5 is an EXCELLENT version and has many advantages over the latest Cura (and vice versa).
Your problem has nothing to do with cura or the "origin". for some reason that is all there is to the STL file. Try opening the STL file in a different viewer such as meshlab or meshmixer. I think you will see the same result.
If it was an origin issue then you would see the part extending BELOW the print bed as kind of a shadow.
It would do this by the way (show it below the bed) in Cura 15.X or Cura 4.X.
tinkergnome 923
well.... the model is very tiny.... only 0.3mm thick
Depending on the first layer height it will be printed with only one or perhaps two layers.
It seems that your expectations are different?
2 hours ago, tinkergnome said:well.... the model is very tiny.... only 0.3mm thick
That's the problem because the model has 3mm thick, not 0,3mm. So maybe the problem is when I export to STL. I use Inventor for design by the way.
Your model is also about 5mm across. Is it supposed to be 5cm? Maybe all your dimensions are off by exactly 10X?
STL files have no dimensions. The standard in 3d printing is that everything be in mm but some CAD expoert in cm or inches.
tinkergnome 923
14 hours ago, Joaquin87 said:That's the problem because the model has 3mm thick, not 0,3mm. So maybe the problem is when I export to STL. I use Inventor for design by the way.
If there are no options for the export units in your CAD software, just use the scale function in Cura.
Cura 4.x shows the size in the lower left corner, so first scale the model to the expected dimensions and you're good to go.
- 2 years later...
How did you solve. Designed part attempting to purge and print beside bed.
GregValiant 956
@atlake247 This is a 2 year old thread.
If your print is showing up off the build plate but the purge lines are OK then you might have "Origin at Center" checked in the Cura machine settings. In most cases it should be unchecked. It depends on the printer.
If both the purge lines and the model are trying to print off the plate then the problem may be in the printer firmware as the Home Offsets determine where the gcode origin is placed. There might be something in your StartUp Gcode as well.
Guest maht
This version is old and unsupported now. Please update to 4.5 and see if the issue persists.
