When you have an Sous Vide stick or an ultrasonic bath, it helps a lot to speed up the dissolving of PVA. Personally I use a cheap sous vide stick and keep the water temperature at 35°. The flow helps to dissolve it faster.
But in very small holes it will also not help too much. For such things you should really use the support blocker as ultiarjan said.
ultiarjan 1,216
There are differences in solubility between different brands of PVA, but more soluble also means harder to print, so probably not the best trade off.
It's better to use "support blocker" in cura to avoid support in places you do want it, don't ask me to explain how as it's not the most intuitive function of cura...
