6. Feeding the filament is a bit of a pig. I've found it often jams so the knurled feeder just grinds into the filament and your print job is destroyed. This is using the PLA filament roll that comes with the machine.
This hasn't happened to me. There is a screw in the top of the feeder. Turn it so that the little white square is near the top (almost as loose as possible). When the white square is down lower the other gear seems to get jammed and it doesn't feed as well.
gr5 2,330
Yes! Fix this now! You probably don't need any tools. It should turn on immediately when you power your machine - even before the lights come on! Roll back/slide up the black plastic mesh above the print head. This will expose some wires and connectors. The 3 red/black cables go to the fans. The pink/blue one goes to the rear fan. It's either unplugged (likely!) or one of the black/red/blue or pink wires might be loose (give them a gentle tug?).
Let me know if you need to know where the other end of the pink/blue cable goes. I have a picture somewhere.
