A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
nallath 1,118
Aborted means that a user decided to abort the print (either via API or via interface).
Failed is that the system had to stop the print (in this case because the printer was powered down, which you can see from the "source" field)
