flnielsen 0
Hi again,
I investigated the Print Head once again, and I found that the small metal sheet at the bottom was bent.
You might be able to see it on my last picture.
I took it out, made it flat, and assembled the Print Head with Print Cores.
After this, I was able to start a print, including the Active Leveling.
I guess that I accidentally had bent the metal sheet during removal of the defective Print Core.
Since a lot of printing material was melted around the Print Nozzle, some material did also stick to the metal sheet.
So the problem is now solved.
How do I mark the post "Solved"?
