Thanks for the response, do you think there needs to be support within the inside of the shell form aswell to print the top red indication?
I don't think so.
The red parts are not an indication of what *needs* support, but of what will *get* support wth the current support overhang angle. But it does not take into account the "support placement" setting. It really is just an indication; not an error or warning that the world will explode if you try to print this without supports.
Common sense is more important than the red indication here.
Edited by ahoebenI would set the support placement setting to "touching buildplate" only.
- 2 months later...
Hi cgeneee!
Judging on the amount of area that the print is touching on the buildplate, it only seems that a brim around 10-20mm around the print is needed.
On 3/17/2020 at 12:02 PM, gr5 said:I would set the support placement setting to "touching buildplate" only.
However, as gr5 stated, it is probably best to enable "touching buildplate" for supports.
In cura, there should also be a setting called “support overhang angle”. You can play with the numbers until you feel that amount of supports are sufficient.
Hope your print turned out well (even though I am late to answer)!
ahoeben 1,723
Since the contact surface at the bottom is fairly small compared to the size of the model, supports might help or even be necessary to keep the model attached to the buildplate.
