Thank you for replying @nallath. I'm trying to see if I can determine from the the temperatures and fan power if there has been a fan, heater or even a filament jam. Ideally I would be able to detect it far enough in advance to warn someone to pause a multi-hour print or even to perform maintenance before it started.
In addition to the printer data itself I would need to know if anything broke on that run.
nallath 1,080
I'd love to give you this data, but we're in the exact same situation.
What kind of data do you need? We might have some older data that we could re-use for this.
