i am trying to add a script to start g code in cura, i tried to copy and paste, however it wont let me past into the box. what am i doing wrong.
Not 100% sure, because it is too long ago that I used Cura 3, but I guess you have to choose the Marlin flavor instead if the Ulticode to use the start gcode.
Please explain what you mean by "it wont let me past into the box"?
There is no Copy/Cut/Paste context menu, but you can use the Ctrl-C/Ctrl-X/Ctrl-V keyboard shortcuts for the same functionality.
ahoeben 1,965
Go to the “Printers” pane of the preferences and press the Machine Settings button.
