The head never leaves the top so the PLA never has a chance to cool enough to become solid.
It does not just sit there and melt, it swirls around whilst chucking out a lot of material. to be honest I think there is a fault.
I'm printing at 220 on the quick print settings.
could someone tell if these things are faults.
1. It does not print when I click print. I have to go into the jog settings and jog the x, y and z, otherwise it will start printing with the build platform at the bottom.
2. the prints are printed on the platform about 2cm to the left from where they are on cura. so does this mean the x and y are out of alignment.
3. some times it prints with no material coming out because the filament has retracted half way down the clear tube. some times the material comes out in spots like there's a blockage. most of the time when printing, the feeder make a ticking noise every 3 seconds, I would not think anything about it but the manual says this indicates a blockage.
4. when the print has finished the print head does not cool down and the platform does not lower. Is this normal?
5. I ran the bed levelling wizard in cura and when it drew a line round the plate the print head smashed into the metal clip that holds the glass on the platform. it take it that can't be right.
could someone please advise since I have only had the machine 3 days and I need to make sure that these things are faults and nothing I could have done before I get the shop to replace the machine.
gr5 2,181
What temp were you printing at and were both side fans running? Assuming those settings are reasonable, the next trick is to print two of these at the same time - place two into cura and then under "machine settings" set the gantry height to zero which forces both prints to print simultaneously - that way each part has time to cool while it prints the other.
Also make sure you don't have "support everywhere" turned on for this part. You can probably almost get by with zero support. Personally I would but a little support in the CAD model instead of letting Cura do it.
Is there any chance you can lay it flat on it's back? Or is the back side as complicated as the front side?
