Many thanks Robert. Good start however
Is there any way to have a look at these github files without having to download the program, create an account, and do a checkout?? Pretty annoying system...
Look on the right hand side and you'll find a button that says "Download ZIP".
The Public assembly guide is now on grithub to download.
b.t.w. do you know what displaytype is used in the Ultimaker 2 ( its an OLed, but cant find the type )
Greetings Adriaan
Another trick with github is you can drill into the directory structure, find the file you want, click it and you will see the contents on an HTML page (if it is a type that can be displayed). If you want to download it, right click the "Raw" button and the "Save as".
It's an OLED with an SSD1309 controller.
It was ridiculously difficult to source in blue. But they are quite common and easy to find in yellow.
Hello Daid,
Thanks for you answer, i did find the SSD1309 controllertype in the source but they are all small size 1.5" , the one in the ultimaker 2 is "if i'm not mistaken" about 2,7"
could you state where you got it from ? or a partnumber ?
Greetings Adriaan
IRobertI 513
There is no public assembly guide as far as I know (I wouldn't mind having one myself). But you can find the schematic for the board here:
https://github.com/Ultimaker/Ultimaker2
