I ordered this v2.1.6 with TMC2208 drivers. It should arive soon and i will keep you updated.
According to the seller it should be a drop in replacement (original firmware can be used).
In the past i worked with TMC2130 drivers which did not have potmeters to adjust the stepper current (current could be set programmatically using SPI), but i think you are correct about the 2208's
I read somewhere that the Vref pot setting sets RMS average current. The factory setting of 1.23v results in a current of 870mA average, which i think would be fine for the stepper motors in the UM2+
But we will see. Fingers crossed
1
Torgeir 212
HI Raymond,
Welcome in here.
Sorry to hear about your mishap.
This "new" main board is interesting as it allows to install alternative stepper drivers.
I would ask if this upgrade to silent step, will keep the ultimaker's firmware control of the "current regulating" to all the stepper drivers as it should be, -or do you have to adjust stepper current using the small pot-meter that's located at each of the small stepper PCB's?
Thanks
Torgeir
