Posted · I need to help adjust print quality ,,, please .
Hi
I'm new with 3d printer
I have a problem in quality
I've used printing according to these settings
http://umforum.ultimaker.com/index.php?/topic/1872-some-calibration-photographs/
I suffered from this problem since getting UM2
With all plans , even with the factory default settings
Used PLA
original thing :
http://www.thingiverse.com/thing:88849
My bad thing :
    What speed and temperature are you printing? Do you have retraction enabled? The main problem looks to be that retraction isn't working well, so that the nozzle is oozing plastic during the moves.
    My um2 came default settings for PLA retraction to use 2.5mm. That's not enough. Change that to at least 4.5mm. Someone with a UM2 suggested even more - I think maybe 5.5mm but whatever your retraction is, increase it slightly.
    190C and 20mm is very smart. This is a good setting.
    DO NOT use "default" settings or easy print settings or whatever they are called. Only use expert mode and make sure "retraction" is enabled. Also set the other retraction parameters in expert settings to 0. So minimum extrusion should be 0. Minimum travel should be 0. Otherwise it won't retract at al. Even a minimum extrusion of .1mm translates to 4.9mm of movement if your layer height is .1mm and some of your extrusions for this bracelet look smaller than 5mm. So set these to zero!!!
    Hassan!
    Moderator is right!
    In Cura, in advanced settings, like he says is right!
    In UM2, Maintenance, Advanced, Retraction, set it to 4.5mm or 5mm.
    Next thing, print at 75 speed.
    Update: General rule, slower print=better result. BUT: if you print very slowly, combined with high temperature and high Material flow, then it will ooze.. string,,,
    Thanks, gr5.
    IMPORTANT: You can set the speed right after the print starts.
    So, after the print starts, press advanced settings and set speed 75, temp 195, bed 210, M(aterial)100. There is a speed setting in Cura as well wich is "basis speed". The speed set in UM2 is a multiplier.
    There are 2 more possibilites for your stringing:
    1. The filament is broken inside the Bowden tube (happened to me, can easily happen), which will
    make it NOT RETRACT until you have consumed the broken part in the "front", close to the nozzle.
    Retraction is the activity of spooling the filament 5mm backwards when moving the head to a new location (happens very quickly, and frequently).. so the filament will not ooze during a short move. IF the filament has a break inside the tube it will not be retracted, only the "unbroken part" connected to the spool will move back.
    Second cause: Too slow printing speed, too much material feed (but needs to be way off) if You print at 25 and M is at 100, it could be a problem.
    Suggest print at 75 speed, Temp 195, heating bed 65. check if filament is broken inside tube by looking very carefully.
    The break could already be inside the extruder assembly and so not visible to you, but will eventually "print out", and then the one-piece filament will retract correctly and you will have less or no stringing..
    Lets hear how it went?
    Thanks
    Normally 75mm/sec speed is fine but if you want to reduce stringing it helps to print slower (20mm/sec) because there is less pressure in the nozzle. You probably can print this at 75 but I would try 20mm/sec first.
    Also heat is your enemy for stringing so if you can print on a cold bed instead of heated bed and print on blue tape instead of glass that will also help but I think that you will be okay with a heated bed.
    'm Going to try now
    Thank you guys
    gr5 I not understand , I'm new with 3d printer
    In Cura - make sure retraction is enabled ALWAYS. Must set blue circled things to 0
    retraction1 copy
    retraction2
    On ultimaker, set retraction to higher value than 4.5. I don't know what value to use as I am still new to UM2. There are 2 ways to do this - you can modify the PLA settings permanently or you can just modify for one print. Here is how to do it for one print:
    DSC 6421
    DSC 6422
    DSC 6423
    Unfortunately, the same problem
    Disappointing result
    I can't see the pictures you posted. Also, did you read my previous post? Did you change all those settings in my previous post?
    Eliminating stringing is tricky but possible. The key is to keep everything as cold as possible and make sure retraction is working. Look at the extruder motor. Learn to hear the sound of retraction. Then make sure it retracts every time and watch the filament at the top of the tube. It should go from the top of the tube to the bottom but no farther! This halts the pressure in the nozzle.
    Also some filaments work better than others. I have found white to be difficult but I have still gotten white PLA to work.
    ohhhhh
    I will kill myself
    What was I lack now a new problem
    Error while reading SD-card
    my UM2 Version 13.10-1 \ Oct 21 - 2013
    Cura Version 13.11.2
    Update to the newest firmware using Cura 13.11.2 - if the version string is right, you still have the old firmware which had known SD-read problems.
    And yes, make sure you turn retraction on!!
    Did you mean Update UM2
    I have Cura Version 13.11.2
    There are updated separate for UM2
    How do I update it
    :p:p
    I'm sorry for the many questions
    Connect CURA-pc with UM2 using USB cable.
    Turn UM2 on-
    In CURA: Choose MACHINE, INSTALL Default firmware.
    That updates UM2.
    Hassan!! You have retraction off!! no wonder! I see it in your screen shot!
    I see you have retraction on now. Good. But I can't see much else. How did the object come out? Any better? A tiny bit better?
    Check out this test I did:
    That was 20mm/sec. Every PLA color and brand is different. What was your speed?
    Do you expect it Leveling the build plate to do with this problem ?
    There are no improvement
    I was bored of not being able to get what you paid for the financial futures
    no.
    Please post a much larger version of the picture above. And also where did you get this PLA?
    I can't read the values in the screenshots. The image is too small and when I zoom in it is all blurry.
    75% of speed doesn't really mean anything, if we don't know the speed in mm/s.
    I would recommend to leave the heated bed off, put some tape down.
    Enable retraction, print slow (about 20mm/s), 190°C. If you still get stringing, try 180°C.
    I am looking forward seeing some more detailed pictures, thanks!
    Lets check feed:
    The filament visible through the feeding tube should have a regular thin pattern of
    "teeth", from the feeding mechanism.
    We are assuming that the spool can unwind unrestricted.
    Start by printing a much smaller and simpler object, like for instance
    The Waterpump :
    http://www.thingiverse.com/thing:16145/#files
    In Cura, put speed at 50. Quality at 0.2 (this will still print very beautifully when your settings are right)
    Coose Expert, Open Expert settings, Set retraction minimum And miminal to "0", check ENABLE ON.
    Choose Expert, Switch to Full settings, Layer height 0.2, shell 0.8, Enable ON, Support type NONE, Platform adhesion Brim.
    In UM2 print at speed 70-80-90-100. Temperature 180-190-200-210-220
    This will give you 20 prints. As they come out, mark them with proof marker which settings they "have",
    or you will mess up later.
    Keep Material at 100 and Build bed at 60, for all these tests.
    This is going to take 3 hours all together, and you will get the feel of it after you are finished.
    Then print your complicated thing with the best settings.
    You will then get some stringing.
    Work on the stringing by reducing temperature 5C at the time. You can also change speed..
    so.. another matrix of tests needed. You will then be expert.
    You can not avoid "micro-strings", smaller than size of human hair, but these are easy to remove.
    Remember, most models shown on the web have a fair amount of post-processing, using a little sharp
    knife, etc. Expect to spend 1-10 minutes on your complicated model.
    By adjustments alone, you will be able to print the waterpump 99% perfectly, with no post-processing!
    When you post screen shots, we must have much higher resolution, its impossible to read...
    Nobody here can give you exact settings, we dont know your settings, temperature, material, even table...a too wobbly base for your printer will produce oval holes.. etc..
    Lets hear how it goes..
