Half Cirlces not printing
Posted · Half Cirlces not printing
Hi all,
As you can see on the left we have a model i created in maya. Exported to obj format and then loaded into cura. Now i have conformed all the normals so its facing the right side as i initially suspected that was the issue. If anyone has ideas id appreciate it as this is my first exported model so bound to run into issues.
I understand maya isnt the precision accuracy software that i should be using but i enjoy making models in it quite a lot.
Thanks for your help,
C
    21 minutes ago, Framar said:
    Last time I've seen such odd behavior was caused by the 3D model that is not right.
    I would agree. However debugging the issue is proving difficult.
    I have attached the model for anyone's convenience.
    door v1.obj
    3 hours ago, tinkergnome said:
    That's how your model looks in Meshmixer. I guess it's not close to what you expect, it is not a solid piece, it is not even flat - perhaps the pictures give some clues?
    Another paper with some crucial things to keep in mind:
    https://i.materialise.com/blog/en/preparing-files-for-3d-printing/
    How weird, it looks similar.. outside of maya the obj appears corrupt.. I will be reading the paper you linked. If i find a solution ill be sure to come back and share.
    Thanks for your time
    C
    And the part is not flat either (seen from the side). That might cause you some problem laying the print on the build plate...
