On 5/20/2020 at 7:10 AM, geert_2 said:I use cyanoacrylate glue for PLA, just the standard one. Usually after sanding or roughening the surface with a file. This works well. I also tried using an activator but that makes the glue cure too fast for good alignment. Thin glue tends to soak itself into tiny openings, so that helps covering the whole bonding area.
Thanks for the tip. I did have canoacrylate glue in my possession but your suggestion made me research it a bit more. My current glue is a gel consistency and the dispenser tip was a bit too wide so it wasn't helping. But I found this glue on Amazon which is thin consistency and has special tips for precise delivery. I think that would help a lot. https://www.amazon.com/gp/product/B00C32ME6G?pf_rd_r=4GWFVAQYWRGYJED5YB92&pf_rd_p=edaba0ee-c2fe-4124-9f5d-b31d6b1bfbee
geert_2 543
