On 5/27/2020 at 11:22 PM, JohnInOttawa said:Thanks! Will try that.
Cheers
John
did you find a setting to reduce the stringing on ultimaker tpu 95a?
Cheers
John
Hello David. I was using Cheetah, I did find the newer version of Cura better, but mostly it was improved with adjusting printing orientation.
Cheers
John
Hi John,
Yes the newer Cura is very good for some of the problematic issues, as "adaptive layers" for the overhang (among many thing), -there is just nothing compare to this printing without support up to 90 degrees!...
However, for the issues you've address here, there is a "secret" (IMO) version of CUra that's outstanding and this one is hiding the travel lines inside the wall very well.
An Old version -right, this is Cura 2.3.1.,!
A high number of my very best prints is sliced with this version and I'm still using it very much.
Note: Cura 2.3.1 do not have its own gcode viewer. But else a winner....
But make sure, if you'll try this version,; that's combing mode is off and that Z hop when retraction is not enabled. Very important!
If you like I can show the difference between the versions is alike.
Good luck
Regards
Torgeir
Edited by Torgeir
3 hours ago, Torgeir said:An Old version -right, this is Cura 2.3.1.,!
Are you saying not to use 4.6.1?
Hi davidbitton,
I'd never said so, but if you need to avoid traveling marks in "some" model you make, this old slicer may be the one to use for such a model.
I do really also use Cura 4.6.1 ! Actually a number of versions of Cura, including S3D.
Regards
Torgeir.
I walked away from S3D.
To bad, the gcode monitor in S3D is the best there is IMHO.
When it come to details, there is nothing as I'm aware of, that shows details as good as S3D.
Also the process of replaying the "head track", as lines build up give you much information.
Hmm. Lots of people name this part as "simulator", but it is just a replay function.
Here is an example of a detail from a Fan Duct Holder print.
The print is sliced very well, but have some artifact that is not a failure of the printer..
Here is a picture of the actual printed (detail) part:
Here you can see the problems, yes small but...
Here is the detail picture of this sliced model shown with gcode viewer in Cura 4.6.1:
No fail is shown here, so you may think this is your printer?
Here is the detail picture of this sliced model shown with gcode viewer in S3D:
Here you can see the problem, so my printer is ok..
This is just an example of how important it is to use good known tools to avoid long waiting and many tries before a success.
Well, some said good tools is half of the job..
Just my thoughts.
Thanks
Torgeir
2 hours ago, Torgeir said:When it come to details, there is nothing as I'm aware of, that shows details as good as S3D.
A little bit off-topic, but if you like a detailed gcode preview, you should take a look at Craftware... I'm just saying... 🙂
Thank you.
I'm going to investigate this thing for sure..
(But disagree very much in naming our printed objects 2.5 D, they are really 3D object, so I'd rater said; welcome into the digital world... 🙂 )
Torgeir
ungutknut 3
Check out the "combing mode" options in the travel settings.
Torgeir 205
Hi John,
You should try burtoogle's latest master version, the stringing problems is much less in this version.
Here you'll find it: https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0&lst=
Also, some of the previous versions of cura may work better.
Thanks
Torgeir
JohnInOttawa 99
Cheers
John
