It's not that I'm trying to print a big part, I built the printer so I could when I wanted to. My bed is 310 x 310.
I suspect you're correct about the firmware, in fact, I was able to adjust my config.h to my expected parameters. I have not been able to load any firmware onto my mainboard, Anet 3D ver 1.5 for many reasons.
1. I know just about enough about arduino to get myself into grave trouble but I've tried many hours to get a file that will even go thru a verification process with no success what so ever.
I was hoping that cura would be an easier way out. I'm almost 70 years old and I just don't have the brains for this. I wish I knew someone who could sit beside me and mentor me but that's not likely to happen.
I appreciate your help and I'm open to any suggestions.
Thank you,
Bob
gr5 1,971
If cura doesn't recognize the larger bed then it won't print larger prints at all. I fhte print is larger than 220mm wide then it will go gray in the view and it won't slice. I assume this is not what you are complaining about.
Therefore I suspect Cura is working just fine.
Most printers have only one endstop on each of XYZ axes and then they have a *software* endstop for the other extreme. Usually you can only fix this by building a new copy of Marlin. Did you do this? You would have to modify the bed dimensions in Configuration.h.
Although usually Marlin says something like "printing out of bounds". And you didn't mention that either.
So I guess I don't understand your issue - how big is the part you are trying to print?
