In this case, Cura sees that the gap between the walls is exactly 1 nozzle width, and reckons it might as well fill that in with a straight line. This gives a slightly higher material use, but a stronger part. However, it also comes at the price of printing those walls at a fairly slow speed.
My recommendation in this case would be to set the wall thickness to 3 (which will indeed print like your top picture with the equivalent of 100% infill). Then change the inner wall speed to 100% of the main print speed. (You may need to show the inner wall setting since it's hidden by default.) The higher inner wall speed should work ok in this case since your walls are just straight lines, and with this change, this should print at a speed comparable to or faster than the low infill version. It's easy to see why logically, since the nozzle has to travel the same distance whether printing infill or a straight line of plastic, except now it doesn't have to start and stop periodically to fill in the infill segments.
burtoogle 514
It's because the model's walls are not close to an even number of wall line widths wide. If you want a quick print that should look fine just use a wall line width of 0.5mm. BTW, I use that a lot with a 0.4 nozzle with no problems at all.
StarkFlyer 0
Thanks burtoogle. I used the .5 wall line width to make the print and all was well. You made me think more about line width settings, nozzle size, etc. Found other settings that also worked. Somewhere along the way I saw a "rule," more than once, the line width should be = to nozzle size. It made sense to me so I always followed it.
