I have seen it too a few times, but I never took the effort to remove it, and it never influenced any process.
It will just be the first part to be extruded.
Happens every time, here.
I started to collect them, freshly picked out of the filament driver.
And they are indeed causing trouble there, if you leave them in there...
Thanks guys..
Yep, worked out how to get them out. Thanks for the heads up!
GBR1
Would you mind sharing what you figured out for future readers?
Hi Robert,
I simple pulled open the Bowden tube at the feeder end and pulled the "blob" out.
I am not sure if this is good protocol but I have had 2 now and got them both out the same way. As others have said I think it's probably not an issue just extruding it through it just seemed better to me to remove it if at all possible.
Hope that helps?
Many thanks for all your help on here guys!
GBR1
Usually it's better to push them through than to take the bowden off. Each time you take the bowden off you are in danger of scraping/damaging it with the thin metal blades that hold it in place.
IRobertI 520
Yeah it happens. Usually it's only a thin strand but I guess you could get this as well. I know I had to go back and forth a few times to get my filament loaded the first time (Maintenance menu -> move material).
