I mean, it's almost one option as it is. Changing "Support extruder" sets all the options below to that extruder (which you'd have to do regardless) and then change "Support infill extruder" to your other extruder and you're done.
It's not a super common thing that people ask for since quite often it's not applicable as the support would be stuck inside the model.
2
gr5 1,841
Yes! Great idea!
Cura has this feature. It's more complicated than you show as areas that need support aren't always perfectly flat. But it does save a lot of PVA and for the part you show above it saves a lot of time as well.
In Cura the feature is called... well I don't know what it is called. This feature was added recently so make sure you have the latest version of Cura.
IRobertI 496
You can just change which extruder to use for the different areas of the generated support.
haqbany 0
Hi Thank you, try it but this is very complicated why is not by default as in one click option I hope they add it
