hi
many thanks for the quick reply. I've tried the method you mentioned, using the metal spring from a clothes peg. It seems to be working - I think I'll need to tinker a bit to get the tension levels just right, but that will have to wait for tomorrow. also I feel a bit stupid for not realising I could fit the tensioner to the longer section of pulley
Anyway, once the printer is up and running I will print the part you have linked to. many thanks!
IRobertI 517
Your build envelope will not be affected if you install the spring in the correct location. For example, to tension the belt closest to you when facing the machine; move the head to the left or right end stop and then install the tensioner on the opposite side as close as possible to the pulley. With the tensioner installed in this location you will be able to move the print head as normal and it wont affect your build envelope at all.
Personally I used piano/music wire to create tensioners which worked quite nicely but I ended up replacing them with these:
http://www.thingiverse.com/thing:17058
