Hy!
Thanks for the answer, I try your settings asap and post my experience.
I do not insist to the ABS material, I want an material which it does not deform from the sunlight.
Can you recommend recommend a material that is just as easy to print as PLA?
Thanks
Benji
dxp 20
Hello and welcome to this forum, Benji!
You want to support those square areas in the second pic? You may want to experiment with Support-Z-Distance and Support Roof. Try to minimize (even zero) the z-gap between until ABS sticks to PVA. A roof is better for adhesion and surface.
It is a good practice to find the right parameters with a small part... 🙂
Cheers,
dxp
